Hello out there. Bought a Rochester 4 barrel at a swap meet yesterday 3/8" fuel inlet nut type, 7042202 DJ- 1723. Is it for a 1972 US automatic? Also I once found somewhere that Australian built cars had the digit 8 in the second last spot on the first group of numbers eg 7042282.is this true of Australian built chev engined cars from HK to HQ? Any help appreciated thanks Oily.
70 = Rochester Products Corp 4 = 1970 to 1975 2 = 1972 2 = Federal standards quadrajet 0 = Chevrolet 2 = Auto
DJ = customer code 1723 = 21 Jun 1973?
172 = 172nd day of the year 3 = year
are you sure the last bit is 1723?
Thanks: 1 times Was thanked: 557 time(s) in 532 post(s)
HK dont have the 8 for Holden, well most of them dont.
HK don't have the 8 for Holden, well most of them don't.
more numbers....put a large air cleaner on it and you wont even see the numbers
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
I think the issue here is not how big an air cleaner you can install but more regarding a particular carby for a particular application. Commencing 1969 production, all Australian application carbys had the character '8' as the second last digit in the pa
I think the issue here is not how big an air cleaner you can install but more regarding a particular carby for a particular application. Commencing 1969 production, all Australian application carbys had the character 8 as the second last digit in the part
Thanks folks for the replies, As 80569K said the two sets of code on this carby have conflicting dates that is what was puzzling me,as that is definitely what it is stamped. The other bit about the australian 8 or US 0 for the second last digit was ju
The date stamps are often out. I've seen it on plenty of carbs when the year in the main number is the year before the year in the second number. Even as much as what you have (ie about 6-8 months).
_____________________________________________________ |
The date stamps are often out. Ive seen it on plenty of carbs when the year in the main number is the year before the year in the second number. Even as much as what you have (ie about 6-8 months).
______________________________________________________ |
