How much would I need to drill out the stud holes on HQ steel rims to make them fit onto the Commodore stud pattern, I wont to build a home based trailer to use as a mobile work deck.  Have you hugged an English Bull Terrier today
Joined: 4/12/2005(UTC) Posts: 1,062  ![Australia Australia]() Location: western victoria
IMHO..Too much, go buy commodore rims.
"Junk is something you throw out three weeks before you need it" |
Fossil fuels are YUMMY ! |
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
For a non road use trailer just fit them straight on.
Thanks guys, I have a mate with a VN differential that hell give me for a small rust repair on his utility. Ill do the same as the HQ differential cut out the center housing and weld in some round tubing to the desired length.Im a firm believer in recycli
simpler to bo;t vb/vh hubs om. remove the disks or leave them on,wont hurt. bolt straight on
I just drilled out the holes a little then tiged a thick washer onto the nuts and then presto they fit perfectly. Im even making the bench area so it can be raised and lowered to suit what ever Im working on. Thanks for the advise guys.
Have
