Will hg 6inch rims fit on a hk that has 5inch rims. Thanks
Joined: 4/12/2005(UTC) Posts: 1,062  ![Australia Australia]() Location: western victoria
Memory aint what it used to be but I would say "YES".
"Junk is something you throw out three weeks before you need it" |
Fossil fuels are YUMMY ! |
Yeah they will. HK 6" wheels had to have wheel spacers to fit them on V8 manual GTSs, and HT/G wheels with the bigger offset solved this.
_______________________________________________________ If we all had the same (good) taste, who would buy all th |
Its a hk prem will 5inch on front and want to put 6inch hg rims, will i need to put spacers?
No, as above you only need spacers with HK 6" rims, and only on V8 GTS manual. HT-HG 6" wheel are a different offset to HK 6"
