hgkid1 Offline
#1 Posted : Saturday, 25 October 2008 1:16:57 AM(UTC)
hgkid1
i have just put a bonnet catch on my vc and something is bent i think because it closed fine but now it wont open... what can i do to get in? i need to do some under bonnet work and cant get the damb thing up now.
on a similar note are bonnet pins legal for road use?
coopers308 Offline
#2 Posted : Saturday, 25 October 2008 4:34:54 AM(UTC)
coopers308
Did you just replace the part on the bonnet? If so you might need someone to push down on the bonnet over the catch area while you pull the cable, this usually works then you may have to try moving it slightly. If you dont have anyone around, as you pu
