Rhys Offline
#1 Posted : Tuesday, 28 October 2008 8:31:25 AM(UTC)
Rhys
Hi All,
Are the brakes on these just as easy to bleed as non-ABS vehicles or are there some tricks to doing it? Also are any non-standard tools required to bleed these brakes properly? I want to change the fluid as the vehicle is 4 years old now and the brakes have never been done.
Any advice much appreciated
Rhys
#2 Posted : Tuesday, 28 October 2008 10:12:07 PM(UTC)
Hi Rhys.
To bleed ABS brakes properly, you need a pressure bleeder & a scanner.
Its not good practice to bleed ABS system by just pumping the pedal & if you dont use a scanner, you wont get the old fluid out of the ABS pump unit.
Dr Terry.
