roy1126 Offline
#1 Posted : Wednesday, 5 November 2008 10:02:03 AM(UTC)
roy1126
Hi all
Quick questions. I have the trimatic auto in my HZ. Do the aussie manual gearboxes use the same cross member as the trimatic and do the aussie manual gearboxes have the same engine mounting pattern as the trimatic???
#2 Posted : Wednesday, 5 November 2008 11:07:41 AM(UTC)
even the tail shaft should fit. i would be looking for a 4 speed from a WB-VB as they are a full cable. if your going to go thru so much effort for a 4 speed. why dont you looking into a spura 5 speed. standard form they are alot stonger than an a aussie
