Hi all Just had a thought do HT Monaro door trims fit HK monaro doors? Only reason I ask is that I know that HK sedan doors are different from the HT-HG sedan doors. Info appreciated. Thanks Stephen [email protected]http://gallery.oldho... |
Coupe doors are the same HK-HG
With the HK front doors, (except Monaro) its only the early cars which are different. Holden moved the interior door handle rearwards (about 2.5") in late 1968. AFAIK the later 68 & all 69 HK front doors are the same as HT/G. Dr Terry Edited by user Tuesday, 16 December 2008 8:30:23 PM(UTC)
| Reason: Not specified |
Ok thanks HK1837 and Dr Terry |
