kanks Offline
#1 Posted : Thursday, 5 February 2009 7:42:11 PM(UTC)
kanks
hi can anyone give me a step by step plan to replace these on my hg as the last set i had done cost me heaps to do.i would like to give this ago and have acces to a good workshop thanks.
#2 Posted : Friday, 6 February 2009 9:51:11 PM(UTC)
There is no rocket science in doing the front ends up as i have done many over the years , but asking for a step by step guide on here is a bit much. Try buying a factory workshop manual if you are addiment to do it yourself .
If you have no luck and wan
Edited by user Friday, 6 February 2009 9:53:47 PM(UTC)  | Reason: Not specified
81837 Offline
#3 Posted : Friday, 6 February 2009 11:23:17 PM(UTC)
81837
I did this a couple of years ago but cant really remember the details. I asked a mate who said he uses an oxy to burn the old bushes out, but I didnt like the sound of that.
As I recall the top control arm can be unbolted and done in the vice.
The lower
kanks Offline
#4 Posted : Monday, 9 February 2009 5:31:43 PM(UTC)
kanks
thanks i will give it ago thanks for the info
Clawd Offline
#5 Posted : Saturday, 14 February 2009 8:30:24 AM(UTC)
Clawd
Its not that hard, I made some of my own tools similar to the factory item, a large split washer cut to fit in behind the bush when pursuading the bush out.
A 2" round piece of pipe cut to form a "C" to slip in behind the control arm to allow you to k
HG Monaros for ever!
This page was generated in 0.111 seconds.
