dede Offline
#1 Posted : Friday, 20 February 2009 12:32:00 AM(UTC)
dede
Hi guys, message of thanks especially to 302 Superbird, Munro 73, XB 351 and Snappa: Appreciate your interest. Update is, have traced vibration to the dif. Had diff modified (removed and re-set saddles and re-welded) It's so much better now. Still a bit shaky over 100 km's but it seems very dependent on the bitumen surface. The smoother the asphalt the smoother the car is. But still not as smooth as a lot of cars I guess it's still an old car that's been lowered, modified etc. Will keep all your info in mind for next probs!
snappa Offline
#2 Posted : Friday, 20 February 2009 5:29:02 AM(UTC)
snappa
Good to hear Dede, I would say the diff housing has warped a bit, they have been known to twist. Keep an eye out for a new housing. I have seen fully rebuilt diffs for around $1500-$2000 after delivery depending where you live. Depends on how much you wan
351 ZH
