knute Offline
#1 Posted : Friday, 20 February 2009 4:30:26 AM(UTC)
knute
what temp should you set your electric fans to cut in at ? my 308 hq ute needs to know
if i have a 92 degree engine thermostat, is it any use setting the fan thermostat at 80 degrees, or do they just work against each other
at the moment, i have them set on (an indicated) 75 degrees, the engine seems really hot and the fans run most of the time
p.s. its about 32 degrees in the shade atm 5.30pm
basketcasebear Offline
#2 Posted : Friday, 20 February 2009 5:05:55 AM(UTC)
basketcasebear
hey knute,
i installed an aftermarket elec fan on my 308,
it cuts in at 80deg,,it works, i have a temp gauge, and it seems correct.
i dont know yet how it goes on the road yet, as i have to do road trials,
but the engine does not seem to be running ho
DOH!!!
greenhj Offline
#3 Posted : Friday, 20 February 2009 5:07:23 AM(UTC)
greenhj
you need to set the fans so the OFF point is slightly higher than normal running temperature, otherwise the buggers stay on all the time.
If your using screw in senders, try an 90 on/85 off, and youll be close.
Im using an 85 on/80 off and the engin
Edited by user Friday, 20 February 2009 5:08:49 AM(UTC)  | Reason: Not specified
#4 Posted : Friday, 20 February 2009 6:12:52 AM(UTC)
I agree, set it just above normal operating temp.
A 92 degree thermostat is too high for an HQ. Even HX onwards ADR27A engine were 190 F (88 C).
From memory the HQ factory one was 180 F (82 C), so run that or a bit less for good measure.
knute Offline
#5 Posted : Friday, 20 February 2009 6:27:57 AM(UTC)
knute
hi
the fans are a really old pair of davies craig that i bought about 20 something years ago. they are the big motor not like the modern "pancake" type and the both of them fairly fill the finned area of the radiator
atm, they are running "open", in
