Evil Homer Offline
#1 Posted : Monday, 9 March 2009 7:39:01 AM(UTC)
Evil Homer
hi have just fitted and new oil pump to my 253 and there is no oil pressure at all. does not even pump oil out of the oil sender.
can anyone help?
bundybluedog Offline
#2 Posted : Monday, 9 March 2009 8:30:07 AM(UTC)
bundybluedog
is the drive for the pump broken? did you put petroleum jelly on the pump gears? its always good to to pack the pump gears with vaso to create a good seal to start the oil sucking thru the pick up, the gears alone may not have a perfect enough seal and th
This page was generated in 0.016 seconds.
