Just got set of CV8R Rims 18 inch to fit to WH statesman will 235X40 series tyres fit on car without any clearance problems or will this cause problems ,Does anyone run this combination on there car, And is it OK or should i look at smaller tyres. Thanks
Try the Street Commodores forum.
James
You only have to be in front at the end of the race. |
Having trouble getting on to that site for some reason someone on this site must have a answer to this
You didnt mention any suspension mods so Im presuming its all stock???
People are running 19" with 245/35s on the rear with minimal scrubbing and 235/35 on the front no probs so Im guessing 235/40/18 would be fine.
If there are any dramas on the bac |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
If the rim offset is the same as the WH Grange youll be fine. It runs 18s with those size tyres, and has no probs, even lowered.
A lot of people aim to achieve nothing |
