jimpram Offline
#1 Posted : Wednesday, 22 April 2009 11:40:36 PM(UTC)
jimpram
Towards the rear of the BASE of twin throttle manifold
(approx. 2/3rds of the way down the middle towards
the rear on the valley cover itself)
there is a round hole with a tapered edge the size of a 50 cent piece.
Any one know what belongs there?
Is it a grommet of some sort?
If so what is the grommet made of.
Plastic, rubber or metal/plastic etc.
Or is it something else all together?
Like some sort of breather for instance.
CAN ANY ONE HELP PLEASE ???
Edited by user Thursday, 23 April 2009 2:23:12 AM(UTC)  | Reason: Not specified
Dr Terry Online
#2 Posted : Thursday, 23 April 2009 4:12:00 AM(UTC)
Can you post a picture, Im having trouble visualising what you are referring to.
Dr Terry.
#3 Posted : Thursday, 23 April 2009 5:16:13 AM(UTC)
A T-piece goes in there that has 2 PCV hoses running off it:
The one off the left goes to the air inlet pipe to the throttle bodies, and the one off the right connects to the PCV valve.
______________________________________________
jimpram Offline
#4 Posted : Thursday, 23 April 2009 7:01:57 AM(UTC)
jimpram
Thanks for your input Dr Terry.
Thanks for your answer to my question Mick.
Solved our problem as someone else had told us
to use a rubber grommet and when we started the engine
for the first time it got sucked in to the engine.
Is this an orig
#5 Posted : Thursday, 23 April 2009 8:09:45 AM(UTC)
Try your nearest Holden dealer tomorrow.
The grommet is part # 7439585
The T-piece is part # 92060582
The grommet is the same as what goes in the end of the blue & black carby V8 rocker covers where the PCV valve & PCV vent plug in (one on each sid
jimpram Offline
#6 Posted : Thursday, 23 April 2009 9:18:57 AM(UTC)
jimpram
Thanks for that Mick.
Your help is much appreciated.
Regarding getting those two parts (grommet+T-piece) from Holden.
They are obsolete.
Rare Spares carry the grommet but not the T-piece.
I will have a look at a universal type T-piece that
Rare S
Edited by user Friday, 24 April 2009 5:18:38 AM(UTC)  | Reason: Not specified
#7 Posted : Friday, 24 April 2009 4:05:25 PM(UTC)
Good to hear you got it all sorted.
