#1 Posted : Friday, 30 May 2008 1:40:10 AM(UTC)
Hi all, Im led to believe the holden water pump is better than the aftermarket ones, ok thats fine.
What id like to know is how many gph these pumps will flow or failing that, what pump speed these are most efficient at.
Im trying to compare apples and oranges (electric vs. mech. Bearing in mind I have no idea about pressures etc which is important when comparing pumps)
Overheating blah blah blah..
Thanks all.
