Joined: 10/07/2024(UTC) Posts: 15 ![Australia Australia]() Location: Huskisson
Hi all, can someone share part numbers for all type 2 engines. I am in the process of gathering all the bits and pieces and the old owner seems to have a lot of it, just want to confirm the numbers.
Thanks: 1 times Was thanked: 586 time(s) in 555 post(s)
If its old stuff it won't have any part numbers on anything. You only got them on new parts, and normally only when you bought them as parts from Nasco/GMP&A. |
Hi Hk1837, sorry wrong terminology. Casting numbers etc? Like heads are 3927188, intake 3927184 etc
Those are about the only two casting numbers of importance other than exhaust manifolds, from memory the driver side is the same as the rest of HK. Block is obvious by the engine number. I’ve never bothered looking at anything else like water pump. I think that is about it, possibly the bellhousing? |
