Hk Prem 350 Chev Offline
#1 Posted : Sunday, 1 September 2024 11:29:12 PM(UTC)
Hk Prem 350 Chev
Hi Guys maybe a stupid question as I'm new to this car stuff but if my car is sitting there idling for 5 mins or so with the radiator cap off then I turn the car off the water just pours out the radiator from like a pressure build up or something which I find strange because the cap was off.
Any ideas or reasons for this?
stevo Offline
#2 Posted : Monday, 2 September 2024 7:12:10 AM(UTC)
stevo
pressure test the cooling system blown head gasket?
GM bleed us dry and run away.
Oily Offline
#3 Posted : Monday, 2 September 2024 8:24:12 AM(UTC)
Oily
Engine still releasing heat to coolant but coolant not circulating due to water pump no longer turning results in the convulsions you mention.
Will be worse with head gasket or thermostat issues.
This page was generated in 0.112 seconds.
