RestoMania Offline
#1 Posted : Wednesday, 21 January 2026 3:27:52 PM(UTC)
RestoMania
I will introduce myself along with some information and pictures of my Kingswood.
I am Peter from Brisbane. As a young boy and into my teens I dreamt of owning a GTR Torana. Unfortunately it never happened. If only I knew then what a collectors car it would become.
Purchased my first car, a HT Belmont, when 18. Kept it for 3 years. Purchased the HJ Kingswood from Andersons Auto City, Gladstone in 1977 as the second owner with 24,253 kilometres on the clock. It was pretty much a fully optioned Kingswood, 4.2 litre, T bar automatic, GM factory integrated air conditioning with tinted windows, tinted top band laminated windscreen, power steering and metallic 2 tone paint.
The car was initially a showroom demonstrator with the first owner apparently being the ‘milkman’ in Gladstone from the mid 70’s. (If anyone here can supply further info on the original owner I would be most appreciative)
I drove the Kingswood for 25 years, retiring it only due to the cost of petrol to keep it running. The car was than stored in a shed for 17 years before deciding that it should be restored. So the project begins.
I am not a mechanic, self taught from growing up on and then owning a farm for some 20 years. So plenty of potential questions to the knowledgeable people on here.
Some pictures of the car after being pulled from shed after 17 years of storage.
Edited by user Monday, 16 February 2026 10:18:21 AM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 21 January 2026 3:50:28 PM(UTC)
Was thanked: 583 time(s) in 553 post(s)
Welcome bud.
I have a HJ Premier similar but has far better paint on it still. Yours looks like it might be a 1974 compliance as I cannot see any canister hoses on it? Mine has a few more options, it's a 5.0L, LSD, air, steer, sports dash, console shift, power windows, wide wheels, power antenna, heated rear window. The part on yours you will find almost impossible to procure is that vacuum operated heater tap. I paid something like $350 10 years ago for a NOS one.
If you post up its VIN plate details I'll look it up for you, see where it was sold etc.
RestoMania Offline
#3 Posted : Wednesday, 21 January 2026 4:22:47 PM(UTC)
RestoMania
Thanks HK1837.
It is a Feb (IIRC) 1976 build. It does have the canister just no hoses connected after I installed a Holley 350 carburettor.
I don’t have any pictures of the VIN at present. Will take one when I next visit the site where it is stored.
You are right about the heater tap. I am also worried about finding a new/second hand rear bumper. I don’t think the damage to it can be repaired to as new condition.
#4 Posted : Wednesday, 21 January 2026 4:27:22 PM(UTC)
The best mod you can make to that car is swap the intake to a HJ or Torana 5.0L one and fit a Quadrajet off a WB or VC-VH 4.2, plus put in a HEI distributor and coil.
You'll find a rear bar easily, might need re-chroming. You won't easily find a heater tap. They are only on HQ-HJ V8 with C60 aircon.
RestoMania Offline
#5 Posted : Wednesday, 21 January 2026 4:49:12 PM(UTC)
RestoMania
I was planning to keep it as original as possible but the more I get into it the harder it is to do that. The biggest problem I find is that it is hard to obtain ‘correct’ information plus newer technology like the HEI distributor and coil is a desirable upgrade.
I pulled the inlet manifold off the other day only to find it had some corrosion about the size of a match head that was letting water leak into the engine. Do I repair or go as you suggested? Decisions decisions.
#6 Posted : Wednesday, 21 January 2026 5:00:53 PM(UTC)
You'll pick up another intake for a HJ 4.2 easily, very few people want them. A HT-HG will fit as will a HQ one but they do have different casting numbers and some minor differences. A 5.0L one will look just as original, will use the same choke pipes and throttle cable etc. Air cleaner looks the same too. Here is my HJ when I changed it back to an orignal Quadrajet
RestoMania Offline
#7 Posted : Sunday, 8 February 2026 8:37:39 PM(UTC)
RestoMania
HK1837, I have a picture below of the VIN plate you requested earlier.
VIN plate
#8 Posted : Monday, 9 February 2026 5:22:44 AM(UTC)
Remind me in early March if I forget to look it up.
RestoMania Offline
#9 Posted : Saturday, 14 March 2026 9:19:29 PM(UTC)
RestoMania
HK1837, you ask to be reminded about finding details on my car from the supplied VIN. Thanks
#10 Posted : Sunday, 15 March 2026 2:14:59 PM(UTC)
I knew you'd need to remind me. Nothing super special about it, but it does have a few options.
H375590 was an Acacia Ridge built and assembled HJ Kingswood sedan, completed on 6th February 1976. Must have been a stock order car (or from what you said a Dealer Order or possibly demonstrator) as it wasn't registered until May 1976. Optioned with L32 (4.2L V8), M40 Trimatic, C60 (integrated A/C) and N40 (power steering). Standard 2.78 rear axle. It was credited as sold by Leach Motors Northside in Windsor. Its engine number was recorded by Leach Motors if you do not have that part of its history, starts with QR7106.
RestoMania on 15/03/2026(UTC)
RestoMania Offline
#11 Posted : Sunday, 15 March 2026 8:09:47 PM(UTC)
RestoMania
Thanks for that info HK1837.
When I purchased this car in Gladstone I was told it was a one owner and owned by a local resident, I assumed it was sold as new there too. Could have been purchased by a Gladstone resident from Leach Motors. Who knows!
I will start another topic showing the cars restoration.
Blu253 Offline
#12 Posted : Monday, 16 March 2026 10:06:25 AM(UTC)
Blu253
Looks nice in Antelope 👍🏻
Current daily drivers
VFII Sportwagon SV6; BF Astra RS
In the shed
VH Vacationer Pacific Blue 4.2
#13 Posted : Monday, 16 March 2026 10:50:47 AM(UTC)
One of my drive and wreck cars years ago was an Antelope HJ Premier sedan. It had Chamois/Covert trim (60V) though. It was an L31 M41 car with air and steer but the standard column shift. Nothing wrong with it, pretty much rust free too just faded paint. It was fitted with LPG too. I bought that around 1996 for $2000 with 12 months rego. Used it as a daily until rego ran out and wrecked it.
This one (H375590) with Gazelle (64V) is getting close to the end of that that colour (and Fawn 64V or 64W on a Belmont or Holden). HJ changed to the new LX Torana colours starting 3/76, and can do crossover in PSN. The last Acacia Ridge 64V car I have is H380137 a 3/76 Kingswood ute and the last 64W is H382234 a 4/76 HJ Holden van. The first 67V/W Acacia Ridge car is H379849 which had 67W (Brown) trim and was a Holden utility, also 3/76.
Edited by user Monday, 16 March 2026 11:00:51 AM(UTC)  | Reason: Typo
