HQforme Offline
#1 Posted : Thursday, 22 January 2009 9:43:50 AM(UTC)
HQforme
Can you adjust the throw on standard HQ clutches? My pickup points so low it's almost like the clutch is only JUUST disengaging. I also get some shudder when in neutral and if it's hot, doesn't like to go in gear.
It's a red 202, 1tonner clutch spring and standard 6cyl box.
I had something similar on my old Alfa when we recut the flywheel. Had to space out the pivot bolt for the clutch fork.
"Silly modern cars"
