#1 Posted : Wednesday, 2 February 2005 1:06:24 AM(UTC)
OK have sourced a complete setup for my HZ 308 with T400 tranny which is dual fuel. Now what is a good initial timing spec for this setup, would it be fine to set it the same as what I run now (about 14 degrees BTDC at idle in drive, aircon on) to suit the LP gas, or should that come back a bit now? I'd love to hear from anyone running this setup on a red 308.
Peter
