#1 Posted : Monday, 7 February 2005 6:52:13 AM(UTC)
My HG prem has the typical opened up seat tops from sun damage that i'm going to have a go at repairing with some similar coloured vinyl from a parts car.I've cut a piece to use for patches from an undamaged area at the bottom of the back seat that has aged similar to mine and matches quite well.What i'd like to know is how do you remove those panels behind the front seat,are they glued or pressed on with some kind of stud?.Also can someone recommend a strong upholstery glue i can use to glue on the patch pieces.Thanks
