patlin Offline
#1 Posted : Sunday, 5 June 2011 8:55:06 AM(UTC)
patlin
Hi FOR SALE IS MY 75 MDL LX HATCHBACK TORANA SL MDL. SELLING AS UNFINISHED PROJECT WITH 95% OF WORK COMPLETED. SELLING BECAUSE I HAVE LOST INTEREST AND DON�T HAVE THE TIME TO COMPLETE OR USE. CAR IS UNREGISTERED WITH MY INTENTIONS WAS TO COMPLETE AND USE ON WEEKENDS DRAG RACING AS HOBBY. CAR IS RUNNING A 400 CHEV ENGINE WITH 4 BOLT MAIN. I DONT HAVE ALL THE SPECS OF ENGINE AS IT WAS BUILT BY PREVIOUS OWNER WITH LITTLE RUN TIME ON CLOCK AND WAS RUNNING VERY STRONG WITH LOTS OF POTENTIALL BEFORE I HAD IT REMOVED FOR ENGINE PAINT JOB, INSPECTION, NEW REAR MAIN SEAL REPLACED ALL ELSE LOOKED OK. ENGINE HASNT BEEN STARTED IN PASS 5 YEARS, THOUGH I HAVE ALWAYS TURNED ENGINE BY HAND. I HAD CAR PAINTED 4 TO 5 YEARS AGO IN 2 PAC BUT CAR HASN'T LEFT SHED SINCE OR EVER SEEN WATER SINCE PAINT JOB. COLOUR IS TOYOTA BISHOP BLUE WHICH IS SIMILAR COLOUR AS FORD XR BLUEPRINT BLUE. NICE COLOUR. NOT A SHOW CAR BUT NEAT AND TIDY JOB. CAR COMES COMPLETE WITH MOST PARTS TO FINISH, MOST REPLACED WITH NEW PARTS.
THE CAR HAS WITH THE FOLLOWING..
400CI CHEV ENGINE 4 BOLT, BLOCK CAST P/N 3951511
HEADS ARE CAST BOWTIE PHASE 2, P/N 14011034 PORTED AND POLISHED TO FLOW AROUND 500 HP ONE OF TUFFEST CAST BOWTIE HEADS MADE.
750 HOLLEY DP CARBY NOT USED SINCE FULL REBUILD KIT REPLACED
EDELBROCK BOWTIE VICTOR JUNIOR MANIFOLD.
ACCEL ELECTRONIC DISSY AND 10.5MM LEADS (NOT FITTED)
NEW PRO ELECTRONIC READY TO RUN DISSY AS OPTION (NOT FITTED).
ANOTHER SET OF 8MM LEADS
B&M MECHANICAL WATER PUMP.
4000 RPM STALL CONVERTER
2 SPEED POWER GLIDE GEAR BOX
HURST PRO SHIFTER
DIFF FORD NINE INCH 4.11 RICHMOND GEARS
31 SPLINE AXLES
NEW RACE SEAT FIXED BACK WITH 4 POINT MONZA HARNESS
NEW CONVO PRO WHEELS FRONTS 15X4 REARS 15X8.5- 3 3/8 BACKSPACE
NEW FRONT RUNNER DRAG STAR TYRES
NEW REAR STREET TYRES TOO MOVE CAR AROUND NOT TOO RACE ON
NEW FUEL SYSTEM, RCI FUEL CELL 30LT, PRO COMP 150 FUEL PUMP
NEW MOROSO IN-LINE FUEL FILTER
NEW � INCH BRAIDED FUEL LINES AND -8 FITTINGS
NEW CASTLE HEADERS TRY Y'S HEADER PIPES (NOT FITTED)
NEW GEAR REDUCTION STARTER
NEW 6 POINT BOLT IN STEEL ROLL CAGE AND PADDING
NEW TAILSHAFT LOOP
SMALL KNOWN PROBLEMS TO CAR, VERY SLIGHT DIFF OIL LEAK (ONLY GASKET TO REPLACE)
CRACKED FRONT WINDSCREEN WHEN ROLLCAGE WAS INSTALLED RECENTLY.
SOME SMALL PITTING MARKS IN PAINT ON BONNET.
TO COMPLETE TO TURN KEY WHICH WOULD ONLY BE A WEEKEND IN SHED FOR SOME WITH KNOWLEDGE�HEADER PIPES NEED FITTING, FRONT BRAKE LINE TO BE FITTED, BATTERY AND WIRING, AND JUST GENRAL BOLT ON'S, AND WIRING TO SUIT.
CAR COULD POSSIBLE BE PUT BACK ON STREET WITH SOME WORK IF DESIRED. HAS BUILD/ID PLATES.
WOULD CONSIDER SELLING AS ROLLER AT THE RIGHT PRICE.
ALL THE HARD WORK DONE, GOOD CLEAN NEAT CAR WICH NEEDS TO BE COMPLTED TO HIT THE TRACKS OR STREET. TO MUCH POTENCIAL TO JUST SIT IN THE SHED FOR TOO MANY MORE YEARS. MY LOST IS YOUR GAIN..WILL BE SADLEY MISSED! Asking $19,900 or will consider swap trade for registered streeter VH,VK,VL commodore must be V8.
LOCATED MARYBOROUGH VIC 3465
PLEASE CALL,TEXT OR EMAIL [email protected] FOR ANY QUESTIONS OR TO ARRANGE VEIW. 0418382732 OR 0354647355
thanks Shaun..
Edited by user Sunday, 5 June 2011 7:53:42 PM(UTC)  | Reason: Not specified
