KRUPTOR Offline
#1 Posted : Monday, 28 November 2011 1:36:47 AM(UTC)
KRUPTOR
Here i have my mk2 ford escort ghia sedan which has a V8 cleveland in it with a C10 auto and a B1800 diff CIG locker and 4.444 gears.Standard 13inch escort steel rims,with 15x6.5inch ranger rims on the rear.Tailshaft loop/shortened E series diff,alot of fabrication etc.700 vac holley,2inch spacer,electric fuell pump/fuel reg,battery in boot.Solid mount engine plate,VN 5L alternator 85amp,modded extractors with a twin 2.5inch exhaust dumped at the diff,sports steering wheel.Has a hurst shifter,with a monster tacho and shift light,oil and water temp gauges and a fuel gauge under bonnet.V8 XE 3 core radiator with twin AU thermo fans and a trans cooler,racing style seats.Still needs some upgrades down but not a bad start.Car is not registered.
The escort was taken to PCM 2011 just in september gone and didnt miss a beat.
http://www.youtube.com/watch?v=9TFCwZNDqRA]Performance car mania Winton 2011 ford escort burnout - YouTube
http://www.youtube.com/watch?v=BkPSMU-T6aU]Performance car mania Winton 2011 V8 escort burnout 2 - YouTube
The engine oil has started to go milky,and the auto has a leak,still driveable.
If you need anymore info can contact Bryan on 0439189312 or email at [email protected].
Car is located in lower murrumbidgee area NSW,looking for $5000 or SWAP F100,Bronco,Chev,Dodge,tow truck,rolling shell,etc.
Edited by user Monday, 28 November 2011 1:42:30 AM(UTC)  | Reason: Not specified
