Gday Fellas, Thanks for the help with the reversing lights. New problem, Hazard lights flash twice at odd occasions. Is this a fault code or just a fault with the indicator circuits?
Cheers, Pete. Old Holdens never die, they just go faster. |
The common fault is usually no blinkers, which is cured by wiggling the hazard switch a little.
But yours is the opposite!
Indicators (hazards) flashing just twice is generally only a result of pressing the button on the key, but knowing how common the faulty hazard light switch issue is, I would be looking their first.
A lot of people aim to achieve nothing in life - and have amazing accuracy. |
Be enough for me to get rid of it.
Thanks for that, Mick.
Ive seen this a few times. Its a problem in the blinker switch.
Just replace the switch assembly.
Dr Terry |
