#1 Posted : Tuesday, 2 August 2005 10:34:05 PM(UTC)
Need some advice in regards to setting up a weber on a 202.the weber does not have a vacum pipe connection , do i require this or do i just run pipe down side of motor to vent! , also what is the best way to setup the choke as i am told it needs a 7 volt's connection to work, if so what do i system do i need to set this up.
thanks bob
