barber Offline
#1 Posted : Thursday, 6 August 2009 5:07:30 AM(UTC)
barber
can u put vs heads on a vn v6 3.8 ltr engine
[SORARE]
[SORARE]
[SUPDUP]
#2 Posted : Thursday, 6 August 2009 4:19:22 PM(UTC)
The VN-VR V6 block is 1" taller than VS in the deck height, which leaves you with no manifold options, as the heads are too far apart at the top for the ecotec manifold that suits VS-VY V6 heads.
Im puzzled as to why youd want to do this? If you want VS V6 heads, just drop a whole ecotec engine in and be done with it.
