We have made most of the Holden Plastic grille badges is it worthwhile making the HJ HX Kingswood grille badge Les
Thanks: 1 times Was thanked: 620 time(s) in 585 post(s)
These are standard on HX Holden based Sandman as well, so not just Kingswood. Probably because HX Holden specification got a HJ grille whereas HX XX7/XU3 got a Kingswood grille. Therefore might be worth it, depends upon minimum quantity I suppose and return.
Hi Les.
Im a little confused. Are you intending to make the HJ Kingswood grille badge i.e. the flat black emblem insert. Or are you meaning the large lion type badge as on the HX Kingswood.
Confusion exists because the HJ type badge carries over to the HX base models.
_______________________________________ There are 3 types of people in the world. 1. Those who can count. 2. Those who cant. |
Sorry for the confusion I did not look up the parts book correctly It is the flat black plastic insert
Hi, can anyone tell me the part number for an HX grille badge?
Which one? Belmont/HOLDEN, HOLDEN tonner, Kingswood/Sandman, Premier/Ambulance etc?
