Anybody know if I can adjust the carby float level without having to take the carby off? This is a standard 202 red motor.
Yes you can.
Remove the 6 screws (7 if its 1976>) holding the carby top on & you can get good access to the fuel bowl.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
