Joined: 2/02/2009(UTC) Posts: 567  ![Australia Australia]() Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 32 times Was thanked: 9 time(s) in 9 post(s)
While in the thoes of a clean out before we move house I found this part. Holden PN 281469. Looks like a the gasket/rubber mount for a wiper motor on the K-T-G range. Black rubber, vaguely triangular shape with 3 mounting holes,and the motor shaft hole in the centre.
Can anyone confirm please? Google hasn't helped.
Cheers and Thanks. |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
Thanks: 1 times Was thanked: 626 time(s) in 590 post(s)
I don't think it is that one, it is p/n 7432324. I think you are missing a digit too. |
There is a number missing there should be 7 digits
Opps. My bad. PN is 2815469.
Cheers, |
yep. its wiper mtr seal for HQ
Thanks guy. Mystery solved.
Cheers. |
