I have a HX van that had original air con. This has now been removed and replaced with Vintage air unit. Engine Is now LS and External Electric fuel pump and custom drop tank being used. Do I still use the Air Con thermal Fuel sender or non- air con sender? Any info much appreciated and thanks in advance.
Thanks: 1 times Was thanked: 626 time(s) in 590 post(s)
The difference was a vapour return line on the sender. Not really an issue now with those mods. |
