#1 Posted : Monday, 21 June 2004 11:23:37 PM(UTC)
Hello all,
I have been asked to clean out my shed a bit so here are some parts that I would like to get rid of:
<p>
302 & 351W heads $10-$60/pair, XR-XY BW diff 2.92:1 $30, XF disc diff 2.77:1 (no brakes or axles so probably would work with drums) $20.
Capri 4cyl diff $80, Cortina TD6 manual pedal set including Booster/mcyl $20. XA Coupe tail lamps (3) 1 good lens 1 ok lens (are they worth $100/lot?). XD-XF Wagon Hayman Reece towbar $70. XD-XF S pack wheels/nuts/caps (5)tyres are useable but 1 is flat $100.
Grey EA front seats that have been fitted with XG rails so that they will fit any XR-XF/XG(Cost me $140 for the rails) excellent condition $200. Sliding glass sunroof still in box never fitted $70 3.23:1 crownwheel & pinion $offers. Capri V6 diff centre with cactus spider gears but a good spare crownwheel & pinion $30.
<p>
I have some Holden parts too but I won't post them up here. I am just outside of the ACT & can be contacted on 02 6238 2858AH or 0403 765 765 or u9909110<AT>anu.edu.au
<p>
Thanks, Jim...
<p>
#2 Posted : Tuesday, 22 June 2004 2:01:40 AM(UTC)
what diff is the 3.23:1 out of.. what sort of cash do you want for it?
#3 Posted : Tuesday, 22 June 2004 10:30:26 PM(UTC)
The diff gears came out of an XE Wagon. The crownwheel has the left hand threaded bolts in it (supplied). Hows's $30 sound?
#4 Posted : Friday, 9 July 2004 7:52:24 AM(UTC)
cool... when can I get hold of you? my number is 0412 800 187 email [email protected]
