#1 Posted : Friday, 12 November 2004 7:17:56 AM(UTC)
hi need some hints on getting a rear courtasy light cover off whithout breaking it to change globe on a zc fairlane, as ive never done one before any help wouled be great , thanks
#2 Posted : Wednesday, 29 December 2004 12:36:50 PM(UTC)
:-( Err, 30 year old bit of heat damaged plastic... I know where you can get replacement ones, the clip in and if you slide a screwdriver under the edge (if the plastic wasn't Fkd you could lift it one side at a time while gently depressing the clippy bit
