#1 Posted : Monday, 28 August 2006 10:02:22 AM(UTC)
VY SS Ute -
270 rear wheel kilowatts - 232/232 110 Higgins Grind Cam, Comp Valve Springs, Rollmaster Double Row Timing Chain, Throttlebody Coolant Bypass, Maf-Less LS1 Edit, Higgins 84mm Throttle Body, 25% Underdrive Pulley, Bosch 700hp Fuel Pump, $2000- Full Fuel System inc Surge Tank and return lines, All work performed by Horsepower Factory - 3500rpm Dominator Hi-Stall Convertor, Stage 2 Shift Kit, Large Trans Cooler, 3.9:1 Diff Gears, HM Tri-y S/S Headers, Delco 1.75lt Hi-Flo Cats, 2 1/2" Redback Cat Back X Pipe & Mufflers, Custom Duel Rear Resi Set Up & Stainless Tips - Wheels Front = 19" x 8.5" Fusions with 235/35/19 Hankooks Ventus Tyres, Rear = 19" x 9.5" Fusions with 265/30/19 Hankooks Ventus Tyres, Kings Lowered Springs 60mm Front & 90mm Rear, Whiteline Alloy Strut Brace, Fusion FE-504 4 Channel Encounter Amp 4 x 100WRMS, 2 x Fusion FEW-10 - 10" Encounter Sub Woofers In Custom Boxes Behind Each Seat, HSV Maloo Tailgate, Seats & interiour, M5 Style Mirrors, Series 2 VY Tail Lights, Chev Grille, HSV Gauge Pod & Gauges, HBD Hard Cover, Billet Alum Oil, P/S & Surge Tank Caps, HPF Tail Shaft Loop, Custom Alloy Oil Catch Can, Full Service & Build History, 1 Owner, Brand new tyres & brakes, RWC & September 2007 Reg - Email [email protected] for full details, SLY LS1 Number plates do not come with ute. Make an offer - must go to make way for new project
$30,000
For full ad and photos see car point ad below
http://carpoint.ninemsn.com.au/used-car/HOLDEN/UTE/Victoria/1714531.aspx
