#1 Posted : Monday, 7 March 2005 3:08:23 AM(UTC)
Hey folks a mate and I have just removed his old amp wire that was run EXTERNALLY under the car :( tut tut tut, It even went along the top of the petty tank.
We are re-routing it through the channel drivers side but we cannot find a hole into the engine bay from the drivers floor area.
Save for drilling. Is there some obvious hole on VNS i dont know about, its not my car I drive carolas :P
#2 Posted : Monday, 7 March 2005 4:16:28 AM(UTC)
Hey buddy if the car is an auto which they usually always are you run the wire though the clutch grommit, its to the right of the brake boster, just poke a little hole in the rubber and your on your way
hope that helps
