#1 Posted : Tuesday, 8 March 2005 2:21:37 AM(UTC)
Can someone please give some advice, I have a 3.9 multi point EA falcon. Air cond is ice cold and now the heater will not get hot, also temp gauge is running above the normal indicator, but not in the red.
The water level is correct and is not boiling.
Question How hot do EA's run at, I have been told not to worry about but I fear the worst may happen? All help would be greatly appricated.
Ron
#2 Posted : Tuesday, 8 March 2005 8:09:56 PM(UTC)
It sounds like your thermostat has jammed shut to me or the air bleed hose from the thermostat housing back to the reservoir bottle is blocked stopping air bubbles from bieng purged. A new one of either is literally a five minute job.
