#1 Posted : Monday, 11 April 2005 12:43:10 AM(UTC)
me missus VC SLE has worn oput the little plastic cogs in the power window mototrs in the 2 front doors. does anyone knopw if these cogs are still available? or does anyone have some good ones that they will sell?? cheers
#2 Posted : Monday, 11 April 2005 1:46:09 AM(UTC)
Grab another motor out of any VB-early VL.
Don't worry about changing the gear over, just swap the motor - they are cheap enough around the swaps & you can use rear ones in the fronts too (side specific).
Preferred option is the late VC onwards th
