Can someone please explain the difference between an EH dizzy and a EJ dizzy?
Hi holdenman.
They are both Bosch & both use the same points, but that's where the similarity ends.
The EJ dissy is smaller in diameter (with a smaller cap)& is made of cast iron. The larger EH dissy has an alloy case. The EJ has the condenser mount |
