#1 Posted : Friday, 22 April 2005 10:42:48 PM(UTC)
for sale $750ono
i have a 149 red motor head ith has o/size stainless valves with hardened seats it has been ported and 12 port modified to suit tripple carbs it has grub screws added to the press in rocker studs it will increase compresion ratio dramatically would best suit hi performance tripple carb set up or lpg set up was removed from my fj as i needed to lower my compresion ratio i had it fully serviced by superflow at the same time as i had them modify my low comp head it has not been on a car since service
#2 Posted : Thursday, 12 May 2005 2:18:29 AM(UTC)
G'Day Charles,
this head, is it a 149 red motor head, or is it a later 3.3 blue mtor head.
cheers,Pete.
#3 Posted : Thursday, 12 May 2005 6:02:07 AM(UTC)
it is a 149 red motor head that has had the port dividers added I was told when I had it serviced at superflow that they do it to make tripple carbs flow better
#4 Posted : Wednesday, 8 June 2005 8:40:04 AM(UTC)
just refreshing
Edited by user Monday, 4 July 2005 5:24:01 PM(UTC)  | Reason: Not specified
