#1 Posted : Tuesday, 10 May 2005 8:44:43 AM(UTC)
The indicators on my HJ Wagon stopped working recently. I have checked the fuses and they are OK. I even took the steering wheel off and checked the indicator mechanism and that looked OK. The only recent work I have done is replace the standard steering wheel with a GTS wheel.
Any suggestions on what to check next. Is the flasher unit involved?
HJ Wagon
jabba Offline
#2 Posted : Tuesday, 10 May 2005 9:05:42 PM(UTC)
jabba
Try shorting a small length of wire across the flasher unit to see if the indicator lights come on at all. If so, then there's your prob (and a v short term fix is to handrualically flash until can track down new unit).
Check power feed and earth conne
#3 Posted : Wednesday, 11 May 2005 7:49:10 AM(UTC)
Your a legend Jabba - problem solved after testing the flasher unit.
There's my problem.
