#1 Posted : Sunday, 22 May 2005 9:41:24 AM(UTC)
G'day new member and first post on a very perplexing problem. First of I have a HZ wagon with a WB Stato dash and I am having a major problem finding diagrams of where the vacuum lines should go and was wondering if anyone could help me out in that regard. Second for some strange reason every time I hit a bump in the road the heater fan tends to cut out would this me wiring or switches again any help would be much apreciated
Edited by user Sunday, 22 May 2005 10:07:47 PM(UTC)  | Reason: Not specified
#2 Posted : Sunday, 22 May 2005 11:21:30 AM(UTC)
Do you have the WB Stato Aircon or the HZ version in your car. I assume you are using the WB controller in the dash.
If you have the HZ version, E-mail me thorugh my profile as I can help you out.
If you have the WB version, I have a diagram of the
Edited by user Sunday, 22 May 2005 11:22:02 AM(UTC)  | Reason: Not specified
#3 Posted : Sunday, 22 May 2005 5:53:27 PM(UTC)
Hi Guys.
You've still got that diagram , Dave. Did you get everything to work ?
To answer HZWGN's query, it does matter whether you're using the HZ a/cond or the WB Statesman's. As Dave mentioned, the face level has 2 sections on the WB to become bi
#4 Posted : Sunday, 22 May 2005 10:54:24 PM(UTC)
Hi Dr Terry,
PM sent.
The Qute slowed down dramatically as I ran out of money...I'm just now preparing to change the motor and box (to RB30/JATCO) and always planned to put the aircon in at the same time, so this is very timely for me.
However, I
#5 Posted : Monday, 23 May 2005 4:28:43 AM(UTC)
Hi Dr Terry
PM Sent
I am using the WB Stato air-con unit not the HZ one.
Thanks for your help
#6 Posted : Sunday, 29 May 2005 3:54:48 AM(UTC)
Well after quite a bit of mucking around I managed to get the vacuum lines working without any help from anyone and now my heater/air-conditioner works the way it's supposed to. Dr Terry thanks for your offer of help and to you to Qute it was much appreci
#7 Posted : Tuesday, 14 March 2006 6:07:59 AM(UTC)
Also a new member, and would dearly love to know where the vacuum lines go on the WB Statey air cond. controls. Yes, I have the Statey version
hjyoot
