hi can anyone tell me where the engine number is on a 2000 holden rodeo with a v6 in it? thanks
Hi nathanq.
It's in a bad spot on this engine.
You will find it low down on the block, passenger's side, towards the rear. Just above the starter motor there is a cast 'pad' with the number stamped.
You will need a torch & probably a hoist.
Dr |
thanks very much for that
