Hi, does anyone know what the Tacho with adjustable redline dial came out on? I heard once they were Bathurst dashes but not so sure now
Hi hg80737.
AFAIK the only tacho with the adjustable redline was the HK GTS type.
Dr Terry. |
Hi Dr Terry, similar thing but definitely T/G - possibly was Brougham only?
Hi again hg80737.
The HT/HG Brougham had a small clock as well as the standard speedo, fuel guage & warning lights, only the GTS got the tacho as standard equipment. It was an option for all cars though.
You mention 'Bathursts dashes', there was no |
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
I've found the red needle on some HT/G dashes and not on others. I remember hearing that either T or G had it and the otehr didn't, but I've never bothered confirming. |
HT have adjuster, HG do not.
Warren
Thanks Warren, Byron and Dr Terry, that's that little mystery solved then.
