#1 Posted : Tuesday, 26 July 2005 1:09:33 AM(UTC)
http://www.milura.com.au...rpage/images/andy98.jpg
and will it fit / line up with my WB tonner?
#2 Posted : Tuesday, 26 July 2005 1:42:42 AM(UTC)
HQ statesman.
It won't line up because the creases in the cowl changed and they don't match up to the bonnet.
The WB tunna also has a few changes to the front legs of the chassis - not sure if this affects fitment of an older front.
#3 Posted : Tuesday, 26 July 2005 4:11:40 AM(UTC)
Hi Ben,
As Commodorenut said, it will (almost definitely) bolt on, but won't line up with bits of your WB. Another problem beside those listed above is that your guards are cut off quite high in front of the front wheels, so you will have quite a gap t
Edited by user Tuesday, 26 July 2005 4:13:05 AM(UTC)  | Reason: Not specified
