need information about engine conversion my lj come standard with a 4cyl 4spd manual dont know if this model can fit a 6cyl. please email. [email protected]
does anyone have any suggestions
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
Same body, different front panels and front end. |
is it worth maybe looking at putting a rotary or some other 4cyl with power in it .
has anyone done any engine conversions like this? what sort of motor can i put in it? (without too much body modifycations)
A bloke i met dont what your looking to do. He unstitched all the ftont end off and LJ 6cyl so he could bolt the subframe upto the correct rails. a few mods on the firewall to take the length. and whamo its in. after alot of hradaches and fights with the
A common conversion for the old LJ 4cyl is to use the 2lt gemini motor and 5sp box, then if your keen stick a turbo on it !! good luck.
When the green flag drops the bulls@#t stops!! |
"Such is life" |
