Hello everybody, I'm wondering if its possible to fit LC-UC Torana brake stubs to the HD-HR subframe. Why I'm asking is I want to fit Commodore discs to the HR. Regards Owen and Ned.
God is Dog spelt backwards.
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
AFAIK they fit. HQ-WB ones will also fit if Torana do, but will make the car sit about 3/4" lower than the Torana ones. HK/T/G are also similar. Just remember to swap them side for side to suit where you want the calipers. |
Whats AFAIK mean, I see where kits are available for this conversion but I thought they were pulling my leg so alls good now.
Hi Guys.
When I use it, I use AFAIK to mean 'As Far As I Know'
Dr Terry. |
yes it is possible but torana stubs give 1.5 degrees inclination and you will never get it straight even if you have wheel alignment done if you want to run commodore discs it is better to use HQ stubs
