Hi Guys, have searched requlary on the net for info relating to the Brougham{specifically the HK}.Have come up with stuff all info. Maybe there isnt much on the net to find.If any of you happen to know of any possible sites, i would appreciate it if you could pass them on.most sites ive seen merely mention the Brougham as being released with the HK monaro,then of course the Monaro takes the spotlight from there on!{not surprising realy} Regards Rob. P.S.-what sorta info am i looking for?-ANY INFO. |
be an innovator, not a imitator |
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
I can probably get you approx build data from Ben Stewart - what do you need it for? I know I sent him ID off a very late Pagewood HK Brougham (from the last few days of production of the bulk of the HK range) a few weeks ago, which basically gives an app |
Any info, well that is wide open, like the 253 was to be fitted to export HK Brougham?
As Byron has said there are lots of places to find the info you are after, but the web is notgoing to be one. There are two Brougham clubs in Australia, SA and Qld.
Thanks Guys.yeah i know its a wide open search request,but thats what im after-anything or everything. I have found out the built number of mine,where it was made,the obvious like glide and 307.havent tried the above mentioned car clubs-will do though. u |
Factory workshop manuals are always at swap meets. The HK Brougham/Monaro supplement can be hard to find though. |
So ive discovered Byron! Will keep searching,and thank you.
