i have a hz v8 with a noisy ticking lifter on cold start up. is it a hard job to replace these yourself
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
You will need to change the cam as well, plus I strongly recommend a new oil pump at the same time. To change the cam and lifters you need to remove the timing cover (bit behind the water pump, and the valley cover (commonly called the inlet manifold). Th |
