hahahah Agro thats right, its been that long I forgot.
No problems. Do you need to know the trim colour?
Yep, 18V = "Slate" black vinyl.
I dont know my Sandmans, but in a GTS that trim code also meant there was a red (i.e. crimson) stripe. Answer is probably somewhere in this huge thread!
___________________________ WTB: - HQ coupe front windscreen mouldings - HQ ute antique brown trim - any pieces! |
___________________________ WTB: - HQ-WB(?) bench seat 4-speed shifter - HQ-WB ute rear window - HQ-WB standard rims - HQ-HX coupe front windscreen mouldings - HQ-HX coupe door mouldings (the stainless one running along top of door exterior) |
Joined: 24/07/2005(UTC) Views messages in topic : 158
quote: Originally posted by Devils Grip
Hi all have been reading through this thread and thought I would put up the details of my van.
MODEL- HX8WM70 xu3 BODY NO- 397812b TRIM - 1899 18v PAINT - 567 15945 L31 M21 GV4
Any info would be great thanks, colours etc.
The XU3 indicates Sandman Paint Code 15945 is Jade Green Metallic Trim 18V is slate black vinyl L31/M21/GV4 is 308 / 4 speed / 3.36 Diff
no stripe in sandmans... kingswood styled interiors. gts only had the stripe & insert fabrics, sandman vinyl only.
quote: Originally posted by Mr.Jones
Nice HQ Sandy on Ebay at the moment http://cgi.ebay.com.au/H....c0.m14&_trkparms=66%3A2|65%3A1|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Azure Blue is a colour you dont see very often and non black interior on a HQ Sandy
 8M80TDH323787Q EHQ68628B 6/74
Leroy
"Planet earth is the asylum to which the rest of the universe sends its lunatics" Voltaire
Rarity indeed. Thats only the second HQ Belmont Sandman ute and 3rd non-Kingswood Sandman ute pre mid-HJ I have ever seen. The HX XU3 is the 4th only Acacia Ridge XU3 recorded as well. _______________________________________________________ If we all had the same (good) taste, who would buy all the Fords? |
Jade Green HX Sandman Ute tags    Nick
Hi sandman gurus.. Went to the outlaws place in tassie on the weekend and the son has a van sitting in his to do list which looks to me like a genuine sandy. Can someone confirm?? So i can tell him he needs to get it out of the rain... details thus - HX8W M 70 239757-A TRIM 1914-18V PAINT 568-17778 L31 M21 GV4 VIN - 8M70TGJ584170X 7-77 BUILD, GVW1950 seat cap 2 white needle GTS dash full length headlining courtesy light switches in doors no tyre placard no motor or box PICS THUS -
Just noticed the column shift thingy there in the last photo. Dont know what the story is there as the tags had original rivets.
hi hainzy... if you say it had original rivets id say definately sandman. even with the on the tree column probably been changed at sometime... front grill is not original maybe its had a front ender? did you check the chassis? scratch the paint back make sure it is aquaris?
HI mate. yep chassis matched.
Tags are definitely from an original Sandman unless it was destined for NZ or imported back from there.
Thanks guys i ll let him know to do something with it before the cancer sets in. Its already getting a bit grim along the pass side gutter and other areas....
Found this HZ base model p/van on Ebay tonight that is advertised as a genuine Sandman. This is a perfect example of how an optioned up base model van can be mistaken for a genuine Sandman. Fairly original van, the front is obviously original to it and I think he may be fibbing about the GTS steering wheel. Not sure how he thinks the Vehicle Identification Certificate verifies it as the genuine article when Sandman is not listed as the model name? http://cgi.ebay.com.au/O...AN_W0QQitemZ320382750921
non derated gvw. will never be able to proove it to be a sandman.
aso my Vechicle id cert does have sandman on it. My hz sandman ute is also a adel build. =) |
It should be relatively easy to prove its not ie lack of headlining and interior light switch wiring. Holden have no records that a van or ute is a Sandman so it is impossible for them to say it is unless its an Acacia Ridge example in which case there is no use getting a letter as XX7 or XU3 is there for all to see. Those letters are next to useless in my opinion as they always seem to stuff something up, which sometimes makes me wonder if its done on purpose. In recent times ive seen repeat examples of a vehicles spec listing as L33 low comp 253 where the BODY clearly says L32 (or blank) and VIN has an R and also M22 where the body plate says M20 and its a 253. These are just the ones I have seen. All Holden can do is look up their records based upon the VIN and tell you what is recorded as mechanical options, when it was built etc. They cannot tell you if the chassis number is right (or even close to right hence the ADR plate matches the others (or not)), nor can they tell you if for say a non-HQ Pagewood van the BODY plate is correct for the other two plates.
Byron, were not talking about the authenticity letter from Holden which is a waste of paper. The vehicle identification certificate is the form (part No. 9944933 for HX) filled out by the selling dealer at the time of purchase and is normally stapled to the inside back of the owners guide, if the car is a Sandman then Sandman is usually written or typed in as the model name.  Edited by user Saturday, 13 June 2009 3:09:02 AM(UTC)
| Reason: Not specified
Got you. You are correct, I was thinking about the letter from Holden. You are correct the owners manual/guide will normally say Sandman if it is. Except for the examples where dealers made their own Sandmans out of BO6 Kingswoods and sold them as such.
hi guys. rob from perth here. just bought a hz sandman project. ne help with a photo or photos in inside trim/dash ect for a van with trim code 63v. will also need much more advise when i start to restore the old girl... thanks to all that reply. rob
