#1 Posted : Monday, 2 August 2004 2:27:34 AM(UTC)
Has anyone on this forum re-wired there HZ-WB with the "Painless Wiring System" ???
#2 Posted : Monday, 2 August 2004 11:48:18 PM(UTC)
I do not understand why you would not just replace the harness with a good second hand one at the wreckers. I am putting an HZ harness into an FC and it took two of us 30 minutes to get it out without damage from a good wreck.
The good thing was one
#3 Posted : Tuesday, 3 August 2004 6:11:40 PM(UTC)
I'm with Warren. My HZ loom was so ratty, I went to a Pick yourself wrecker and spent about 1 hour wandering around, deciding which ute had the best loom, and then removing it. The only thing I'd add is label wires before you remove them, rather than afte
#4 Posted : Tuesday, 3 August 2004 11:15:30 PM(UTC)
Yeah, ive used a painless kit in an EH.. and they are great.
my current project tho, im not using one, but have pulled one from a wreck instead.
this was based purely on $$$. and the harness from a wreck has a nice relay and fuse panel I neede
