#1 Posted : Wednesday, 11 August 2004 11:34:17 AM(UTC)
I have decided to do up a grey motor and box that I have had laying around for yonks.
I don't have a manual.
Can someone tell me what the crank diameter and allowances are for the mains and big ends, and the end float, so I can mike it up?
Thanks.
#2 Posted : Thursday, 12 August 2004 8:11:02 AM(UTC)
Also the engine number is L502454
Casting number 740885
5
H298
Any suggestions what it is out of?
#3 Posted : Saturday, 14 August 2004 3:55:45 AM(UTC)
Crankshaft end play = .003 in to .008 in.
Main bearings----
Bearing journal diameter(standard) = 1.9982 in to 1.9992 in.
Bearing to journal clearance = .0008 in to .0034 in.
Connecting rod bearings-----
Bearing journal diameter(standard) = 1.748
#4 Posted : Saturday, 14 August 2004 3:59:30 AM(UTC)
Hi johnperth.
You're better off getting a workshop manual for all of the specs.
The engine itself is out of a '59 FC.
Regards.
#5 Posted : Saturday, 14 August 2004 9:07:50 AM(UTC)
Thanks Mike and Dr terry.
Would you believe the bores and crank appear perfect, and its still stock?
Will find out how perfect when i mike it tho!
Also it may very well be the original motor for the car it was in when I bouht an old FC wagon with a mot
