#1 Posted : Tuesday, 24 August 2004 7:04:03 AM(UTC)
guy's,
how do i take out both ball joints on my hq?
#2 Posted : Wednesday, 25 August 2004 6:42:22 AM(UTC)
jack the car under the chassis to let the suspension hang remove split pins and backoff the lower ball joint nut.
holding a large hammer against the taper smack the other side opposite with another hammer.
the object is to squash the taper slightly forc
#3 Posted : Thursday, 26 August 2004 5:13:13 AM(UTC)
thanks darrin
#4 Posted : Thursday, 26 August 2004 8:12:28 AM(UTC)
Remove the control arm and press the ball joint out and press the knew one in. It is a lot less hassel and work then trying to hammer one back in, unless you have a short handle 14lb hammer and a good solid short swing. For the sake of only a couple of mo
